Coil driver location and Injector driver location?
Quick question:
Mainly would like to know where is the coil drivers located(ie which module). I think i am having problems at high load the spark dropping out. I have High IDC for the injectors but low Hp. Example motron 60 6lb boost 427ci at 87% IDC making 520rwhp it should be 600 on a A4 3800stall, at 9 lb it made 660rwhp.
Tried a search no luck.
And while i am at it where is the injector driver module granted no search done on this yet.
Thanks
Thanks
Both coil and injector drivers are in the PCM on an LS1 car.
You cannot use corrected rwhp numbers to compare fuel components. If there is is a big positive correction in the summer the car isnt really making that power. If its good weather you are making more power and its corrected down.
Then add big differences in drivetrain losses between big stalled autos with 9" fords and manual trans cars with stock 10 bolt rears and the numbers even get further off. Unlocked you are probbaly down 50-60rwhp.
I made 680rwhp (uncorrected TH400) with 60lb injectors at 97% DC with a solid 65psi of fuel pressure with a centrifugal supercharger. Supercharger eats up about 30-40fwhp also so that skews the results as well. I run my car at 12.5:1 a/f also, if you run yours at 11.5:1 expect to add about another 10% DC..
Originally Posted by hool97
I also here you on the rwhp numbers the 520 is uncorrected in 107degree heat and 129 intake temps.
