Burning out Turn signal/ Back up light fuse
Old 10-06-2006, 12:52 AM
Ehatcher's Avatar
Default Burning out Turn signal/ Back up light fuse
My car keeps burning out the turn signal and back up light 20amp fuse. I just burnt through 3 in a matter of 2 minutes. What could be causing this.. and how can i fix it
Old 10-06-2006, 01:26 AM
staringback05's Avatar
check the load on the wire, the type of bulb, and make sure your using the right fuse...
Old 10-06-2006, 01:32 AM
Ehatcher's Avatar
load on the wire... what do you mean by that? I did have my tail lights off the other day to tint them..... so maybe i crimped something while putting them back on?
Old 10-06-2006, 01:50 AM
the voltage running through the wire....take a voltmeter to it....
Old 11-02-2006, 01:02 PM
98_blk_Hawk's Avatar
having same problem did you find anything out?
Old 11-02-2006, 07:14 PM
any other thoughts?
