ls6/ls1????
Old 10-06-2006, 03:58 PM
00maro's Avatar
Default ls6/ls1????
whats the difference between the ls1 and ls6 engine? i'm new to this, but i've heard that the ls1 and ls6 engines are both 346, so whats the difference?
Old 10-06-2006, 05:49 PM
HeapaShifter's Avatar
Powerwise; different heads and camshaft. Also the LS6 block has better crankcase breathing and the LS6 also has a different PCV setup.
Old 10-06-2006, 06:14 PM
LS1Aggie09's Avatar
dpends what year ls1....the 01 and 02 LS1 were basically an LS6 minus the cam and heads but some had the LS6 block (not that it makes that much of a difference having the LS6 block) and all had the LS6 intake manifold...theres a write up on here thats a sticky that tells the exact differences...
Old 10-07-2006, 03:41 PM
bjamick's Avatar
but not all the 01 and 02's came with the ls6 intake some did but not all. i think like 15% in 01 and like 30% in 02 came with the ls6 intake.. but they all really run about the same no big dif. b/t 99 TA and a 2002 TA they will run the same at the track. but the ls6 had the same CI (cubic inches) BUT came with a dif. camshaft and a dif. intake. bigger TB's,
Old 10-07-2006, 04:33 PM
2001bluerata's Avatar
As far as I knew all 01-02s came w/ the ls6 intake! I think you are getting the 15% & 30% confused w/ how many f-bodies came w/ the ls6 block w/ls1 internals
Old 10-07-2006, 04:49 PM
KameleonTransAm's Avatar
Yes he is getting a little confused. ALL 01/02 LS1 powered F-bodies came with the LS6 intake. However, 15% of 01's and 30% of 02's came with the LS6 block which you can tell the difference between due to the LS6 block being "dull". Whereas the LS1 block is "shiny" for lack of a better word.
Old 10-08-2006, 12:49 PM
bjamick's Avatar
oh ok my bad ya i got it confused my fault...
