Clutch Pedal is bleeding off pressure... WTF?
Old 10-08-2006, 03:35 PM
N4cer's Avatar
Default Clutch Pedal is bleeding off pressure... WTF?
I noticed today it just started. If I'm sitting at a red light when I push in the clutch to go, the clutch engages very low. And the pedal sticks to the floor. This is with a new slave (2k miles on it), new clutch (2k on it), new master (500 on it). So I tried just resting my foot on the clutch pedal while at a red light and sure enough... pressure bleeds off as if the bleeder is open. Only there's no fluid running out. This makes no sense. Anybody have any ideas?
Old 10-08-2006, 03:47 PM
Gold Phoenix's Avatar
I had the same problem on my Formula. I installed a new clutch with a new slave cylinder. After so many full pumps, it felt like there was no pressure until I did very short pumps and I got the pressure back for a while. I thought it was the McLeod master cylinder since I had it in the car for 4 years now. I thought heavy pressure plate loads wore out the seals in it. So I had my Dad rebuild it with the McLeod kit (since I am working in Germany), but now he has nothing. I have another thread asking about the same thing.
Old 10-08-2006, 06:15 PM
6']['9's Avatar
im having the same problem...
Old 10-08-2006, 06:43 PM
EXTANKER's Avatar
it sounds like the master cylinder is bypassing. it wont leak. rebleed,make sure its got the correct fluid. maybe find a way to plug master cyl. the GENTLY apply psi dont push hard something will pop. keep psi on it and see if the pedal sinks
Old 10-10-2006, 05:12 PM
Restricted User
98Z28CobraKiller's Avatar
Where do you plug it? How does it bypass? I am confused. I am having a very similar problem. I even disconnected the hydraulic line from the tranny and I still have no pedal.
Old 10-11-2006, 02:51 PM
N4cer's Avatar
Since mine is new, I'm just sending the MC back to Summit. They've agreed to replace it.
Old 10-11-2006, 03:41 PM
Ramshaft's Avatar
well at least i am not the only one having this problem i just replaced the whole system and the clutch works but it just feels like **** and if i hold the pedal down for a while it will come up about half way and stick.
Old 10-11-2006, 04:50 PM
gun5l1ng3r's Avatar
I too am having a similar problem. If I SLOWLY release the pedal from the floor, it will have a very firm pedal on the next two shifts... After that, the pedal is less firm and more spongy.
Old 10-11-2006, 05:15 PM
malott442's Avatar
Bleeeeeeeed. If not a bleed, then yes the o-ring has gone
Old 10-12-2006, 12:47 PM
Restricted User
Ram and/or Gun, Did you do the drill mod?
Old 10-12-2006, 01:32 PM
gun5l1ng3r's Avatar
yes i did! What has that to do with it?
Old 10-12-2006, 01:34 PM
gun5l1ng3r's Avatar
What o-ring are you talking about?
Old 10-12-2006, 01:48 PM
N4cer's Avatar
I've opened a master cylinder, and don't remember an o-ring in there. Just one-way valves/seals.
Old 10-12-2006, 10:52 PM
Restricted User
The drill mod is supposed to cure the slow pedal after aggressive shifts.
Old 10-12-2006, 11:04 PM
N4cer's Avatar
This isn't an aggresive shifting issue. This is a bleeding off issue. Mine is drill modded as well, for the record.
Old 11-05-2006, 09:41 AM
6']['9's Avatar
anyone find a solution yet?
Old 11-05-2006, 09:53 AM
Sonic28's Avatar
Malott is right. Just keep bleeding the system. The following way is SIMPLE, and VERY efficient. If bleeding the system does not work, you have an o'ring problem.
http://performanceworks1.com/ls1_clutch_bleeding.htm
Old 11-05-2006, 12:52 PM
N4cer's Avatar
Mine wasn't an o-ring. It was the seals in the master cylinder (those aren't o-rings). I replaced it (Summit replaced it without a problem) and all's well.
Quick Reply: Clutch Pedal is bleeding off pressure... WTF?
