3.73 or 4.10 Faster??
Im just wondering what will net me the best ET.Its on a ford 9" with the setup
on my sig.I have yet to get some real times out of it.I will be spraying a 200 shot on it,I just dont want to over rev the engine if I dont have to. I have 26x11.50 Et streets on 15" pro stars.
If I spray A 200 shot with 4.10 and 26" tall tires, anybody have any idea what the RPM's will be at the end of the 1/4mile or 3.73's.I just havent ran it but I got a good deal on a 4.10 currie built center section,so Im deabting in changing it out.
We need to know what rpms your redline is? What HP N/A? To get an idea where you wanna be gearing wise. It's all in the whole combo not just gear ratio! 4.10's with 26" tire is 113mph@6000rpm, 123mph@6500rpm, and 132mph@7000rpm. A 28"tire is 122mph@6000rpm, 132mph@6500rpm, and 142mph@7000rpm. Now you need to know what your N/A mph is and figure how much HP your realistically putting down to the ground! Add 200HP and figure your gearing! As you upgrade HP, you can make tire height adjustments to compensate for more power! Good luck! Hopefully I was helpful!
