Anyone Willing??
Anyone Willing??
to help me figure out what is wrong with my car that has some mechanical knowledge?? I don't want to have to tow it to a shop, and I'm not very mechanically savvy. I'm located in the East Texas area, and would greatly appreciate it. I don't want someone to do all the work, just give me some help. Thanks.
I was driving yesterday, and when I got on the gas, it started spittering & sputtering, and I got off the gas, and it stopped doing it. When I got on the gas again, it did it again, and then died. Now the motor will turn over, but it won't start. It has plenty of gas in it. I washed the motor last weekend, and drove it all week without any problems until Sunday.
Originally Posted by 68shortstep
opti is what is sounds like.....
also sounds like its not getting fuel....fuel pump not working, filter clogged, fuse blown.
the fuel pump should be working. I just changed it out about 2 months ago, new filter also. haven't checked the fuses yet, I'll see what I can eliminate this afternoon when I get home.
It really sounds like your Opti Spark is having problems. If you get the front of the motor really wet it will usually get to the Opti. I don't think the 96 Lt1 had a weep hole in the bottom of the opti. It might not be wet though since you said you drove it for a week. Either way it sounds like the Opti took a shi_. just my .02. Hope it helps some.
well, checked all the fuses, and they are good. the fuel pump is primering as it should when I turn the key on, and when I checked the plug wires, I'm not getting any fire.
It is probably the opti, but on my 94z did the same exact thing. Turned out to be a clogged up cat, and a bad opti. Just get you a broom handle and hollow that bitch out. (the 96's may have 2 dontreally know.)
i think its prolly what everyone else is saying opti, check fuel filter, coil, and some of those other electronics that have to do with with getting spark to the plugs i have my old coil and its good i just got a MSD, if need be ill let you use my old stocker to test your coil see if it is bad (im gonna have to go find it in the storage room first though lol) .... more than likely opti is what it is though
check the fuel to see if u are getting fuel to it...there is a lil cap on the side where is says caustion fuel...remove the cap turn the key forward and press on the lil nipple if it squirts its not your fuel pump......check all yours ground mine was doing the same thing about a month ago and it was som lose grounds behind the driverside head...check that out and then for sure change your opti if u have never changed it....do not get a msd opti spark they suck ***.....just get a o.e.m one
