Which is Better F2 or 88mm Turbo
I already have the turbo but not on the car it currently has an Vortech X Trim only making 16.5 #'s of boost and it still makes over 1000rwhp but need more and I was wondering if the F2 would make more HP than the 88mm turbo?I am limited to either the F2 or 88mm turbo so anything else is out of the ? Just looking for input on these 2.Thanks
Originally Posted by Urban Legend
What you need is counseling, if 1000rwhp is not enough.
Originally Posted by smokinHawk
which 88mm turbo
if its a precision PTE88 (medium frame, T4 or T6 exhaust housing) then the F2 would probably make more.
if it was a precision 88/98 cheater turbo then probably yes.
Can you run an 88/98 cheater turbo or does it have to be a true 88? What's your name btw.
Are you running PSCA or something?
Originally Posted by Jim98TA
Are you the person who bought George Baxter's old car??
LS1Tech Co-Founder
Sounds like you need to research the rules to figure out your options. A true 88mm can run 7.9-8.1's but I'm guessing your car is kind of heavy? What does the class run right now, 7.80's?
Calvert Racing Products
True Street
Driver E/T Speed
1. L. Patrick 8.168@173.25 525 ci BBC on a D/P nos
2. M. Figeroa 8.297@169.34 43? ci sbc on 2 stages @ 295x #'s
3. G. Raygoza 8.327@170.60 525 ci BBC on a D/P nos 3300 #'s
4. S. Oksas 8.370@170.02 43? ci sbc on 2 stages @ 295x #'s
5. B. Kopp 8.427@168.30 525 ci BBC on a D/P nos 3300 #'s
6. S. Zeinaty 8.442@162.12 43? ci sbc on 2 stages @ 295x #'s
7. G. Kent 8.575@166.97 525 ci BBC on a D/P nos 3300# 's
8. J. McDonald 8.747@153.93 me 3300 #'s 408 ci breaking the vacuum pump pulley off and losing some power lifting b4 the finish line
9. R. Klostreich 9.483@139.10
10. J. Orme 10.00@130.00
All of this done on a Junk *** 30x12.5 Et Street
Times in Sig were on a 29.5 10.5w
Here is a link to the rules http://pscaracing.com/Rules/rules_06_truestreet.html this year they only allow an 85mm turbo but there are talks of allowing an 88mm next year.
LS1Tech Co-Founder
Rules sound a lot like NMRA Drag Radial.
You know who you should talk to? Brian @ Precision Turbo? He has personal experience with the F2, and also has a lot of experience with the NMRA 85 turbo crowd:
Brian Malmsten - brian@precisionturbo.net
LS1Tech Co-Founder
I've heard of NMRA Drag Radial dipping down to the 8.2's right now with the YSi at competition weight, and I think the fastest turbo guy went 8.2 as well. I think they might have allowed the 88mm this year but I don't follow NMRA that much anymore.
One of his teammates, Jason Lee, put an F2 on his car and went 7.82 @ 170 (letting off before the stripe) last weekend at Milan on a MT DR.
At the same event that 8seclt1 went his 8.16, Doyle (F1R) went a 8.10, and Kolivas (turbo) did too.
