maf sensor throwing code, replaced,still not working?
replaced my maf sensor today with a new stock one and is still throwing a code! what next? all the wires look in good shape none burned, etc? please help
the pink wire coming off the MAF harness is notorious for going bad on 97 LT1's!!
i had the same problem. replaced the MAF and the code was still there. ended up buying a a harness from advanced for maybe 30$ and replaced the harness and as far back as i could tear the stock loom back. and the code went away after that.
one more thing, after replacing the MAF did u reset the PCM?
u can do so by unplugging the battery or taking the PCM fuse out on the dash, near the driver side door. take it out for 30 secs.
