Louis's short shifter problem
Old 10-11-2006, 09:39 PM
stealth1281's Avatar
Default Louis's short shifter problem
sorry, i am not sure where i should post this, but i got a Louis' short shifter, and am very disappointed with it. It's definately shorter, which is great....BUT......everytime I shift onto 2nd and 4th gear, the shifter bangs off of my center console. is this common?
Old 10-12-2006, 03:58 PM
MavrikTA's Avatar
Ive got the same damn problem. But it seems we are of the very few. No one else has the issues I have. I have asked repeatedly if maybe the people that DONT hit have the factory Hurst. I have the cheap OEM shifter and Id bet you do too. I wonder if switching to the factory Hurst would remedey the problem?
Old 10-12-2006, 04:12 PM
Shirley Temple Drinker
Sgt. Spuds's Avatar
I had the same problem, I just re-adjusted the stops on my pro5.0 and now its prefect no more banging..
Get a pro5.0, dont waste your time on a factory hurst, if your gonna spend money, might as well go all out for not much more.
Old 10-12-2006, 10:04 PM
BitViper's Avatar
Ok..Ill ask..are you sure you have it facing the right way?
Had to ask
Old 10-12-2006, 10:56 PM
SweeTbone's Avatar
I've always read that if you don't have a factory Hurst, it will hit. I'd probably get a Pro 5.0 and use the LSS on that. Take a look at the UMI short stick --> http://umiperformance.com/2105.aspx
It says that it "(Will not fit 93-02 Models with stock NON-Hurst Shifter base)". So I'm guessing that will be the case with just about any short stick.
Old 10-12-2006, 11:05 PM
Sgt. Spuds's Avatar
pretty sure UMI's says that because the bolt pattern is for the hurst and pro5.0, not the factory base.
Old 10-13-2006, 08:36 AM
TeEnAgE pHeNoM's Avatar
Take the shifter handle and turn it the other way. It should have a slight bend on the handle, you want it facing the opposite way it is facing now!
BTW I had this same problem!
Quick Reply: Louis's short shifter problem
