Mahle piston valve reliefs
I am building my budget engine for boost & I am using -4cc mahle pistons. Is it a good idea to round the sharp edges on the valve reliefs to deter knock? Has anyone done this?
Thanks,
Thanks,
If it was a power pak piston its coated...
http://www.mahlemotorsports.com/C125.../mmscat03c.pdf
Mahle's PowerPak piston assemblies include forged pistons, piston rings, pins, and wire locks--all in one race-proven package. The pistons are hand-deburred, and then coated with dry phosphate to protect against ring micro-welding and pin galling during initial startup. For additional performance, Mahle added its proprietary Grafal anti-friction coating to the piston skirts. Low drag rings, steel pins, and round wire locks complete the Mahle PowerPak package.
