Advancing cam?
Advancing cam?
I had installed comp. cam 212/218 .5xx/.5xx lift cam about a year ago. I come to find out it has 0 degrees advance. I know it is a baby cam but have changed direction as far as the performance I would like(more drag racing). That being said and for information purposes had this cam had the typical 4 degrees advance would I have picked up anymore power or simply shift where it makes its power? From my understanding same power but sooner and dropping off early which seems indicative of when I dynoed that power did'nt drop off till 6500 plus.BTW I am thinking on a new cam in the 230/230 range and changing gears to 3.45 just need to go back and read cam discussions for a more informed decision on v.e. Any suggestions?
Originally Posted by Rays C5
I had installed comp. cam 212/218 .5xx/.5xx lift cam about a year ago. I come to find out it has 0 degrees advance. I know it is a baby cam but have changed direction as far as the performance I would like(more drag racing). That being said and for information purposes had this cam had the typical 4 degrees advance would I have picked up anymore power or simply shift where it makes its power? From my understanding same power but sooner and dropping off early.
Are LS1 cams ground differently than SBC cams? I thought comp ground most of their cams with 4 degrees advance to save bottom end for the guys who buy the 'bottom of the page' cams.
Thanks for the info. Trying to decide on a cam now that would net 30/35 more hp /torque I thinking in the 230/228 range on a 114 . Just need to do research on valve events unless there are some suggestions on cams in that range with good v.e.?
Many are making great power with the 224/228 grinds that are available. Check out the Patrick G Torque Cam Thread for more info...
If a set of heads are in your future, this looks like an excellent path.
