who's running a -10an return line?
Old 10-16-2006, 12:44 AM
ls1king000's Avatar
Default who's running a -10an return line?
I've seen only a couple of people run this. Mostly the stenod crew. Does high HP fuel systems tend to flood the pump while at idle?
Old 10-16-2006, 08:06 AM
Coal Mining Director
onfire's Avatar
-8 is fine up to ~1200 engine hp....once the fuel passes through the regulator, a small amount of pressure drop in the return line is meaningless.
Old 10-16-2006, 08:53 AM
Z06kern's Avatar
I agree. Unless you have a motor making big HP -8an is fine. I'm running -6 return in my Z06 and -8 in my Firebird and have no problems at all.
Old 10-16-2006, 05:04 PM
ls1king000's Avatar
I mean, any downsides besides price? I can't even find a FPR -8, -8, -10 return. Looks like this one is a marine FPR.
Old 10-20-2006, 12:39 PM
stevieturbo's Avatar
I have a single -8 feed from pump to the motor. It splits into 2 -6 to each rail, than into a single -6 into a MagnaFuel FPR.
it exits the FPR via a single -6 and returns to the tank....
No problems here, dual Bosch pumps in parallel.
Old 10-20-2006, 03:50 PM
ls1king000's Avatar
Well, I went ahead and jsut bought the aeromotive pro regulator. dual -8an intlet and -10an return.
I just wanted to know if there are any downsides to a larger than usual return line. If not, I can just change the fitting on the reg., Right?
Old 10-20-2006, 04:02 PM
No downsides...but if there was more fuel returning, than entering the reg...I'd be very concerned !!!
