Exhaust Poping
Exhaust Poping
Stand behind car with it running and there is poping sounds coming from the right side of the exhaust. Nothing from the left. Could this be caused by a bad header gasket or should I be looking at something esle?
Thanks.
__________________
95 LT1 209/214 @50 P/P Heads CAI TF Elbow 52 mm TB w Foil Taylor wires MSD coil UD Pulleys SFC LCA 21 mm RSB BMR Adj TA Transgo SK Poly Mounts & bushings Pcmforless Tune Pace Setter LT 3"Off Road Y-Pipe No Cat 3" Magnaflow exhaust
Thanks.
__________________
Originally Posted by Sgt. Spuds
you have a Y pipe, the side that the noise is coming from might not have anything to do with the side the 'problem is on'
This is true, but I do know for a fact that the passenger side header gasket is leaking. Got the bolts out last night and it was shot, now comes the joy of getting my big hands in their to start the bolts. and maybe some but I'll get it done.
Even though the plugs have only been in for 3 weeks, I'll check those while I'm at it.
Thanks for the help eveyone.
