lining up the dots
lining up the dots
When reinistalling the cam gear and lining up the dots on it and the crank gear how close can the dots be and still be off, from one angle the dots look lined up from a different look they look like the might be off by a quarter to a half a tooth, is it possible for them to be off just a few degrees with the setup on an ls1?
I don't know it seems to be pretty much on if not off just a hair, I'm just real sketchy about it being wrong
About the only thing I found to be reassuring about the whole process was when as an experiment I tried to place it off one tooth. Just one tooth off is WAY off dot-to-dot, so it's obvious when you're right.
Originally Posted by TOS98SS
that is the slack in the chain you could if you wanted to turn the crank and they would line up perfect
R/
Frat
