Oil Pressure Survey...
Re: Oil Pressure Survey...
Cold Start psi- 55 +/-
Warm Idle psi- 40 +/-
Warm Idle rpm- needle reads 750
Upgraded Oil Pump? Y/N? No
Cam? Y/N? No
Heads Y/N? No
Oil Brand/Weight 10w 30 Mobil 1 or Royal Purple
Filter Brand/Part # Mobil 1 (M-107)
Cam? Y/N? No
Heads Y/N? No
LS1Tech Administrator
Received 1,492 Likes
Cold Start psi->>> 60
Warm Idle psi->>> 40-45
Warm Idle rpm->>> 800
Upgraded Oil Pump? Y/N?>>> Yes, ARE pump.
Cam? Y/N?>>> Yes.
Heads Y/N?>>> No.
Oil Brand/Weight>>> Valvoline Syn./10W30
Filter Brand/Part #>>> Delco UPF44 or M1-107
Cam? Y/N?>>> Yes.
Heads Y/N?>>> No.
Cold Start psi- 70-75 <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Warm Idle psi- 45-50
Warm Idle rpm- 1000
Upgraded Oil Pump? Y - MTI ported with spring shimmed
Cam? R1 - getting much bigger soon
Heads ported LS6
Oil Brand/Weight Mobil 1 4 quarts 15W50, 2 quarts 10W30
Filter Brand/Part # Mobile 1
Warm Idle rpm- 1000
Heads ported LS6
Cold Start psi- 55 psi
Warm Idle psi- 36-40 psi
Warm Idle rpm-500-550
Upgraded Oil Pump?-No
Cam?-N
Heads-N
Oil Brand/Weight-Amsoil 10W-30
Filter Brand/Part #Amsoil(don't remember off hand)
'99 A4 with 55,000 miles.
Cam?-N
Heads-N
Cold Start PSI: @50 or slightly under
Warm Idle:46
Warm Idle rpm:stock idle for A4
WOT PSI: 60psi
Upgraded Pump: No
Cam: No (stock)
Heads: No
Oil Brand/Weight: Neo-Synthetic 0w-5
Filter/Brand:Canton Racing Products -45 remote
aluminum filter w/no bypass 65GPM #25-100
90 degree billet adapter #22-593
Aeroquip Starlite Hose w/nomex pyro
cover
Warm Idle:46
WOT PSI: 60psi
Upgraded Pump: No
Cam: No (stock)
Heads: No
cover
