HELP Real quick- in the middle of this install
Old 10-19-2006, 07:12 PM
1stz06's Avatar
Default HELP Real quick- in the middle of this install
What is the best way to remove a stripped rocker arm bolt??? Nothing seems to fit these right. I have 2 8mm 8pt sockers and neither one of them would grab well and I ruined one of the bolts. I went and purchased a bolt grip kit made by vice grip and the 8mm that comes with the kit does fit (too small).
Any suggestions please!!!
Changing pushrods 20 min. job and I am going on 1.5 hrs.
Thanks,
J.R.
Old 10-19-2006, 07:28 PM
sprydncamd ta's Avatar
craftsman has a bolt remover kit -your best bet
Old 10-19-2006, 08:26 PM
Moderator
davered00ss's Avatar
I was going to say the Craftsman bolt out kit. You need to be careful, they break easy. I have broken a few of them.
Old 10-19-2006, 08:38 PM
BriGuy's Avatar
Like the others above said, the Craftsman set works like a charm. The only thing that sucks though is I believe the bolts are about $4 each.
