SES engine code P0134 throwing
I had both banks coding and went and bought two new Bosch front O2's for my 02 camaro w/LT's - installed them and am left with the 134 code. I also had a bad MAP sensor code throwing - I installed a new MAP sensor (biatch is on the very back side of the intake mani - hell of a lot of work just for that fokker) - so what is ledt to check? Get under tha car and check the installation, the wire harness plug and so forth to make sure all is well - anything else? Any easy way to check that the plug is live? Thanks for any help guys - stevet
Actually at vatozone the computer gave this message for the code --> P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1) so it is as if the O2 sensor were not there at all - the O2 is bad or the wires or connector is bad or worse a problem somewhere in the wire loom itself......just looking for any suggestions here.
Thanks - stevet
Thanks - stevet
