Drag Racing Tech
Will it hook?
Old 10-24-2006, 06:03 PM
calongo_SS's Avatar
Default Will it hook?
Cam only '01 SS (233/239) 4k stall, regular bolt ons (no EWP of FAST), & 150 wet shot.
More info:
Moser 12 bolt, spool, 3.73's
325 50 - 15 M/T DR's on 15 x 10 prostars (15 x 3.5 up front)
BMR LCA's, PHR, & SFC's
LCA relocation brackets
Jegster T/A set @ -3
Spohn drag sway bar, front sway bar removed
Comp. eng. rear shocks (50/50), rubber isolators removed
Strange double adjustable up front
Hawker battery, !abs
stock K-member & a-arms
Wolfe 6 pt roll bar
Car is about ~3650 w/ me in it. I'm hoping w/ all the suspension upgrades I'm doing I'll be able to hook the 150 shot out of the hole on the DR's, which I have not been able to do thus far. What do you think?
Craig
PS the car traps @ 126.5 spraying ~30 ft out. I should be easily into the 10's with that trap speed right? Currently 11.2 is my best.
Old 10-24-2006, 06:41 PM
FloydSummerOf68's Avatar
I've seen 10 second vettes on a lot smaller MT DR than that cutting 1.5s, so the tire should be capable of handling the launch, but I dont know if your specific setup will or not, I dont know enough to say for sure.
Old 10-25-2006, 09:12 PM
calongo_SS's Avatar
Any more opinions? What 60 ft do you think this tire/suspension combo is good for at my power level?
