Best daily driving cam.
I tried to searched but it's not being to happy for me this morning..
I need a cam that i can put in for a cam-only setup, that can be daily drivin and still sound mean and get decent HP gains.
Stock heads, stock TB.
The only thing i will be changing is i have some pacesetters LT's im going to put on.
I want something that sounds mean.. and that with a good tune with can easily daily drivin with my setup.
Yes i know i will need to change the valve train.. i need a recommendation for that too.
Thanks.
Thanks.
TR224/224 112LSA was an EXCILENT daily driver cam.......it makes good hp (390-410rw depending on mods), has a mild lope, does not need to be spun past 6400/6500RPM (won't blow a rod), does not need any "fancy" valve springs (just some good 918s or other direct swap performance spring will work), "CAN" be run on a stock tune (though it will be a total pig), and just all around WORKS!
also, anyone have a sound clip of this cam with a virtually stock car?
EDIT: https://ls1tech.com/forums/showthrea...4%2F224+112LSA
sounds amazing.. where can i buy one?
the best cam
Moderators..you may now close the thread as it has been answered.
