Bullet/resonator in the I-Pipe?
I have a question:
My current setup is Pacesetter race LT's, TSP ORY, Borla.
This setup is a bit loud for me. Plus...its really raspy under rapid acceleration.
Would I lose any power by putting in a bullet on my I-Pipe? Also, would it help with the raspyness?
If the power loss is insignificant, what would be a good bullet to put in there? Thanks in advance!
MASS seller approved
There will be virtually no power loss putting a straight through bullet in the I-Pipe.
Options:
Dynomax bullet: will clear up about 1/2 to 3/4 the rasp, make it slightly deeper, not much change in noise level
Borla XR-1 bullet: clear up 3/4 to all the rasp, make it quite a bit deeper, slight reduction in noise level. It's a 5" Diameter muffler and is a tight fit in the I-Pipe but it can be done...some banging of the rear seat floor pan MAY be required.
Classic Chambered: clear up 3/4 to all the rasp, make it alot deeper, about the same noise reduction as Borla.
Those would be my top 3 choices. Dynomax is cheapest, than the Classic Chambered, and then the Borla is most expensive. I'd recommend the Borla or Classic Chambered personally.
Options:
Originally Posted by JKDZ28
Thanks for the very helpful replies guys!
What is this "classic chambered" bullet? Is there a site where I can locate this?
Pics/videos/dyno: https://ls1tech.com/forums/generation-iii-external-engine/583963-exclusive-classic-chambered-powerpacks-not-powersticks-pics-videos-dyno-inside.html
Options:
Options:
Options:
Options:
Originally Posted by Judge Smales
Which classic chambered do you use in the I pipe? I have Kooks headers with the GMMG and still get some rasp and would like to get rid of most if possible. Can you install the classic chambered?
Pricing: http://www.eadperformance.com/catalo...cPath=42_75_76
Pics/videos/dyno: https://ls1tech.com/forums/showthread.php?t=583963
Thanks for all the help!
Which would you recommend with the classic chamber. Short, Medium, or Long?
Thanks guys
We can install the muffler, but we are currently moving shops. It would be two weeks or so before we could do it.
Thanks guys
Thanks guys
If you want to quiet your exhaust down some, use the PowerPack, 3" x 16" or if you do not want to quiet it down, get a 3" x 16" Powerstick.
