Fueling & Injection - Tape on npt fittings?
View Full Version : Tape on npt fittings?
nvmy2000ss
10-29-2006, 03:19 PM
I purchased nasty rails and I seem to be having some problems. first the screws that attach the rails to the mounting blocks bottomed out in the block which is fusterating, after cuting the screws and getting evrything mounted in I turned on the ignition to get fuel pressure and fuel comes out of every npt fitting on the ends of the rails wtf :bang: . Is it ok to use tape on those fitting? I was allways told not to. Any help would be great.
RedWS6 00
10-29-2006, 03:30 PM
Didn't use tape on mine, although I dont have the same rails. I think its wise not to use tape.
Are you sure all is tight?
code4
10-29-2006, 08:19 PM
I use liquid thread sealer on all NPT (pipe) threads.
nvmy2000ss
10-29-2006, 08:35 PM
I think this is what I will be doing. ^
onfire
10-29-2006, 08:45 PM
No tape on AN fittings. NPT requires tape or an 0-ring with a receiver groove.
ls1408cp
10-29-2006, 11:56 PM
paste
YoMommasTA
10-30-2006, 12:49 AM
locktite works nice to seal those threads
Nasty N8
10-30-2006, 04:09 PM
The instructions in our install kit specify pipe sealant on all NPT threads.
Nate
nvmy2000ss
10-30-2006, 08:17 PM
Nate
sorry did not come with instructions. I bought them off of a member here, they were new just no instructions.
ls1king000
10-30-2006, 08:30 PM
There should be more write-up's/ stickys for the fuel section. Just small detailed information for the DIYer's.
nvmy2000ss
10-30-2006, 08:51 PM
That would be good. I feel like a dumbass, I really thought you were not supossed to put anything on them. I did use the search but came up with mostly using tape so the hose doesnt fray.
