The bullet?
Old 10-31-2006, 10:55 AM
Mens Rea's Avatar
Default The bullet?
Ok, so I've heard a lot about this suppossed Dynomax Bullet. I was looking it up in Summit and it was only $70. So what is it exactly? A muffler? If so, will I have any trouble connecting it around my current Flowcrap cat-back? Sorry to sound nubbish, but I really do need a different exhaust set-up on the cheap and this looks like the best-way to go.
Old 10-31-2006, 11:54 AM
lt197formula's Avatar
It is a race muffler, basically just a resonator to reduce the sound a bit. Jegs has them for 36.99...
Old 10-31-2006, 01:48 PM
dhdenney's Avatar
The most popular use of the Bullet is running true duals. Have heard of some using them as a resonator in place of a cat. I personally would use them for the true duals.
Old 10-31-2006, 02:36 PM
Boodyrider's Avatar
Factory style is one in two out, the bullet won't be a direct fit. As posted above, could use before the existing muffler as a resonator, or get 2 and do true duals.
Note it is nearly a glasspack. flow is great, but by itself, it'll be loud.
Old 10-31-2006, 03:23 PM
Hot94Z28's Avatar
If you use it in place of your cat it will tone down a bit if thats what you want or do you want to get ride of the flowmaster all together?
Quick Reply: The bullet?
