For those on last page of photoshop request thread
and whoevers blue ta that is the rims are darkened up a bit so they look like they are also in the shadow because it looked a lil funny with the sun shining off them even though suns on other side lol
I had a request for these stripes on my car in a silver metallic color if you could it'd be appreciated.
http://s5.photobucket.com/albums/y15...%20Trans%20AM/
http://www.phoenixgraphix.com/transam/9802fbra.htm
Here's an easy one. Can someone show me what my car would look like with the top painted black as well as the sides that go down from the top?
meh, the lights I think would look pretty good but im a little tired to do a good job on the grill so I'll probably try again when I wake up in the morning.
Ill check back in here tommarow afternoonish for request
Responded to PM here since its kinda long and to include Pics:
1.) Outline the area you want to select with the lasso
2.)In the Pulldown menu goto Layer--> New --> and select "Layer Via Copy"
3.)Make sure your new layer is selected in the layers box in the bottom right
4.)In the Pulldown menu goto Image --> Adjustments --> and select "Hue/Saturation"
5.)Use the sliders you change color, saturation, and brightness
Black & White willl be tough to produce like this, so to get the best color from those two, Desaturate the area and then use the "Brightness" slider to get Black or White. They still wont look perfect but will turn out better.
Thats the best way to change to basic colors, explore the rest of the Image Adjustments to find and you can find other ways to produce different colors/effects.
Candy Red -
Chameleon (ish)
Candy Red -
Chameleon (ish)
