LT1 running bad from 3000RPM and up? Backfiring.Stumbling No power
Old 11-01-2006, 10:19 PM
jdubb168984's Avatar
Default LT1 running bad from 3000RPM and up? Backfiring.Stumbling No power
I have a new Opti Distributor, New plugs and Wires, MAF,Rebuilt 355, New Coil , And Fuel Pump Walbro 255 WTF! It's kicking my ***. My idle is also up about 250 rpms and my car is in and out of Open and Closed loop mode.
Old 11-01-2006, 10:20 PM
Please help. Advise much needed.
Old 11-01-2006, 11:35 PM
the_merv's Avatar
Compression check for the hell of it. Mine was wigging out, and all I had to do was adjust the Valves.
Old 11-01-2006, 11:42 PM
Armyman2445's Avatar
I would also check the plug wires. One might be touching the header.
Old 11-02-2006, 12:03 AM
Well this is a fresh motor with about 3000 miles on it. Have either of you had these problems before? So if the rockerarms are loose ith will do this or if they are tight? I just checked the wires but i will do it one more time. The funny thing is it only does this once it warms up.
Old 11-02-2006, 01:12 AM
infinitebird's Avatar
o2 sensors?
Old 11-02-2006, 09:27 AM
tadevouru's Avatar
If the car only does that when it gets warmed up is a good indication that the wire from the harness to the opti is bad. My car started the same thing, and then it started to go died and would not crank until the engine cooled. I found out that the wire tends to coriode. It could also be the coil breaking down, but if the rpm elevates. then check the wire first.
Old 11-02-2006, 09:35 PM
ZEX-Z's Avatar
Well my car runs great at idle. Just a little high. So do you think it could be the wire leading to the opti.
Old 11-02-2006, 10:23 PM
ZEX-Z's Avatar
Any one else got an idea.
Old 11-03-2006, 09:16 AM
tadevouru's Avatar
I would check the wire first. I have had to put 5 opti's on my car in the past 2 yrs. let me just tell u DO NOT but an aftermarket from a part store.If you don't have an ac delco then that could be it. I bought one from Advance auto and O'reilly's and they lasted any were from one day to 2 mths. I tried 2 from each store and they all failed. Take the wire and on the connector, be careful and pull the rubber piece down from the bottom were the wire goes in. you might be able to see something. If nothing else soak the connector down with contact cleaner. That might help it out.
Old 11-03-2006, 10:54 AM
knight17Z's Avatar
sounds like a bad opti
it took 3 tries for Accel to send me a good one
if the new opti didn't help when you put it on you might have gotten a **** one from the start
Old 11-04-2006, 12:58 AM
ZEX-Z's Avatar
Do you have any idea where to buy the wire that leads to the opti? Does anyone think it could be the ignition control module going out?
Old 11-04-2006, 02:04 AM
Revelation Z28's Avatar
o2 sensors, check plug wires, plugs, and for the hell of it, seafoam the engine.
change your fuel filter too after seafoam.
Old 11-05-2006, 01:05 AM
knight17Z's Avatar
pull the ICM and the coil off and take them into Advance Auto to have them checked out
Old 11-08-2006, 08:52 AM
ZEX-Z's Avatar
any other ideas......
Old 11-08-2006, 08:55 AM
ZEX-Z's Avatar
I changed out the tpi sensor and the ICM and neither of these fixed the problem. I do have aftermarket injectors 32lb accels but do I really need that big of an injector? I have had my heads ported to stage 3 and a 584" lift cam 2.08" 1.62 " Valves ported intake and throttle body.
Old 11-08-2006, 05:17 PM
ZEX-Z's Avatar
So what about the computer stuck in open loop mode? Is this possible and how does this happen...?
Old 11-08-2006, 06:12 PM
RedRocketZ28's Avatar
How hard is it to change this wire? Does anything need to be taken off the car? Also can I buy just that wire at a parts store? I am still learning the LT1 and my car is stumbling in upper rpms too. Thanks guys.
Old 11-08-2006, 06:55 PM
You don't need to take anything off. It's a little difficult to get to, but not all that hard.
Don't know if they have them at parts stores, I found replacement ones on ebay.
Old 11-08-2006, 09:41 PM
http://cgi.ebay.com/ebaymotors/LT1-O...spagenameZWDVW
Is this the wire?
Quick Reply: LT1 running bad from 3000RPM and up? Backfiring.Stumbling No power
