4th gen with a carbed LS1
Originally Posted by blue02formula
Why would you want to? That would be like taking out the CD player to put in an 8 track.
For a consistant alcohol carbed bracket car. Im not interested in fuel economy
btw, EFI is not for fuel economy.. its for fuel control.
even running alky, theres no reason to ditch the EFI..
Originally Posted by Urban Legend
Whats wrong with 8 tracks?
if you mod a 8track player just right, you can hook it up to a TRS-80 so that you can have 8 programs on demand, instead of switching cassettes everything you want to load a different program!
pitfall and star trek sim on the same cartridge!!!
Originally Posted by Cop Car
IMO, carbed intake, elbow, throttle body, injectors
it escapes me how fuel injection would be less consistant on a race track
well, some people dont know how to manipulate it. *shrug*
its more of a knowledge thing then a physical part thing... but its not harder... atleast IMO..
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
This reminds me of the Mac vs PC debate - you either hate one and love the other with little middle ground.
Think it was this year at some car shows some LS's showed up carbed with essentially 'manta' hoods for a bit of a raised cowel, you need approx 1½-2" of additonal room on top though it does depend on what the entire set up is. If your ground clearance is a tennis ball eater you are going to need round 3" additional height for it to fit - if you are closer to stock height you may need no alteration depending on the size block.
My affinity towards having a carbed LS (or LT) is greater than trying to stuff a tt set up though I wouldn't rule it out, just depends on what the finances will be come build time. If I can it will be carbed considering there are some first gens that were haulin' pig weight and still running consistent 13's. With some modding and weight reduction you could easily get solid low 12 runs on the quarter, boosted into the high 11's. FI has its pros and cons as does carbed - its just a matter of what you are more comfortable working on.
Originally Posted by under pressure
So a guy asks a question about hood clearance and now he is "white trash"? Priceless.
Originally Posted by C.J.
kind of what I am thinking, carb in a 4th gen = whitetrash IMO.
OK, so will a carb on a LSx in a 4th Gen fit with just a hood or does the cowl itself have to be significantly modified? I'm with the OP on this, white trash or not some have reasons for wanting a carb, so will it fit please? If not, what changes have to be made, thanks.
