ARP crank bolt....what size wrench?
Hey guys, I'm trying to turn my motor over by hand but seeing as I have a C5 I'm unable to utilize a socket/ratchet with the steering rack in place.
I can however use a wrench, yet I'm unable to remember the 12 point size needed??
Any help is appreciated!
Originally Posted by vettenuts
A box wrench won't fit. I had to make one, I can send you a photo if you want, but basically I bought a socket, sliced it and welded it to a 1/8" flat bar. Then bent the bar to fit around the steering rack. Don't remember the size, but can check later.
On the 45 degree angles you can go a little more for extra room.
1 1/16 and 27mm both work. Just used a box end 27mm for the engine I built. The box end has a slight angle on it that gives you enough contact to turn the engine over, but not for bolt removal/torque. Just curious as to what owning a f body has to do with it
The actual head of the bolt is 27mm huh? I didn't realize it was that big...I thought is was in the 24mm area....
Is it possible for anyone with an F-body to check for me?
TIA!
TIA!
I don't believe that the steering shaft is in the way on F-bods whereas the Vette has the steering rack about an inch away thus causing a problem for simply removing bolt or turning the engine over...
Thanks for the help guys!
No worries guys...I pulled the fuel pump relay/fuse and turn the car over...
I had a good feeling that the setup had plenty of room and I was right...
Please do not use this method if you have any thoughts of it being close!
Thanks for the replies though....you guys are the best!
