What dual spring to use that requires no machining
Old 11-03-2006, 01:23 PM
mvvette97's Avatar
Default What dual spring to use that requires no machining
If I break the 918 springs again I want to go with a dual setup. I need something that will take the 573 lift and still have some left to go. Is there a dual spring that doesn't require head machining? I would like something I can just set up and install. Do they make a dual like that?
Old 11-03-2006, 01:36 PM
V6 Bird's Avatar
PRC's, Comp 921's, Crane 832's all are direct drop ins.
Old 11-03-2006, 01:50 PM
NassyVette's Avatar
PRC's dual golds with titanium retainers, seats and seals is probably the best deal.
Old 11-03-2006, 05:46 PM
JPH
JPH's Avatar
crane, comp, isky, psi. you name it, there all out there by now.
Old 11-05-2006, 12:50 AM
mvvette97's Avatar
will the comp or crane work with my stock valve seals on the 2000 LS1?
Old 11-05-2006, 08:21 AM
GuitsBoy's Avatar
Patriot gold duals! Far and away the best bang for the buck. Fantastic spring.
