Cam installed, car won't stay alive...
Old 11-04-2006, 12:46 AM
916LS1's Avatar
Default Cam installed, car won't stay alive...
I just put in a TR224, and the first two times I started it, it idled without any problems. However, as soon as I put it in gear and tried to drive it, it won't idle at all, it just dies. Once I get it going, it drives nice, sounds good, and pulls hard. Whats going on here??? I triple-checked the plugs and wires, I'm about to reinstall all plugs and wires again to see if that helps...
BTW, the SES light is on steady...
Please help! My first cam install went so well until now
Old 11-04-2006, 12:53 AM
SSilverSSurfer's Avatar
tune...
Old 11-04-2006, 12:57 AM
916LS1's Avatar
Thats it??? I read so many threads about how the TR224 runs so well untuned.
Old 11-04-2006, 01:55 AM
PREDATOR-Z's Avatar
Open your TB blade a bit (via TB blade screw- a bit 1 full turn at a time)
Disconect TPS sensor (bottom TB driver side)
Turn ignition on but do not crank for 30 sec
Turn ignition off
Reconnect TPS sensor
Start car and when warm see if that is better.
Repeat if necessary
This is called a TPS relearn, it will get you by till tuning.
Old 11-04-2006, 02:00 AM
916LS1's Avatar
Wow, awesome Predator! Will do first thing in the morning!
Thanks!
staringback05's Avatar
yea your going to need to get it tuned....tricking it will work for a little while
Old 11-04-2006, 02:18 PM
ShevrolayZ28's Avatar
Read the SES code, this might help you figure it out.
FWIW my HC car ran pretty well without a tune.
Another thought is that your clutch might be dragging just enough to make the car stall.
Old 11-04-2006, 03:56 PM
TOS98SS's Avatar
You may have left a sensor disconnected that is causing you problem the code will point you to the sensor that is disconnced the light wount usually come right on unless it is an open circut
Old 11-04-2006, 04:01 PM
yak
yak's Avatar
yup, do the tps relearn. I got a g5x3 on a 112 to idle on a stock tune with a stock A4 converter and 2.73's
Old 11-04-2006, 04:06 PM
2001bluerata's Avatar
A Tune would help out big time!
Old 11-04-2006, 04:16 PM
RooRnZ28's Avatar
tune it... yes it may run without one, but its gonna be a bitch. regardless of fiddling with things to make it run and crap, you may just make it worse. just get a tune and be done with it. it will save you lots of stress
Old 11-04-2006, 04:24 PM
hotrodrx7's Avatar
Turn ignition off
Repeat if necessary
What he said.
Old 11-04-2006, 04:46 PM
Rob98LS1's Avatar
I noticed your in the sacramento region too. I am looking to get this cam also, think it will pass emissions? I have to change out my LTs for shorties but other than that I'm set to go, I just need to find a cam that will smog and I was hoping this would work. Hope you get it running good.
Old 11-04-2006, 06:57 PM
916LS1's Avatar
The TPS relearn did wonders. Its totally drivable now, but I definitally plan on getting the tune later. Too bad it doesn't lope like I thought it would, must be the damn shorties
Old 11-04-2006, 07:19 PM
Thats Great that it worked for you.
Doesn't lope like you thought it would, that sucks!
Old 11-04-2006, 07:48 PM
One Bad Z's Avatar
Turn ignition off
Repeat if necessary
My car is an auto with 3000 stall and i just did heads/cam (stock ported heads 2.02/1.60 valves 234/242 .598/.610 114 using 7.4 pushrods) and we cant get it to stay running when put in gear. Idles fine in park but dies every time in gear. They tried unplugging the tps sensor but that didnt help. They didnt do the whole wait 30 seconds or anything though. Any thoughts?
Old 11-04-2006, 07:55 PM
Fratsit's Avatar
Don't put off that tune. Take it from me. I put my car on the rollers today (untuned) and found out my AFR is way too lean in the top end.
Even if the TR224 runs well without the tune you dont want to risk it.
I have EFIlive and an LM1 on the way and an appointment for a tune on the 13th.
R/
Frat
Old 11-04-2006, 09:06 PM
Rob98LS1's Avatar
it doesn't lope? All of the clips I have heard were pretty choppy for such a mild cam, even on a stock exhuast setup that I heard. Maybe I will stick with Lts/ory then.
Old 11-04-2006, 11:53 PM
916LS1's Avatar
It has a noticable lope, I just thought it would be MORE noticable. I guess thats a good thing here in Cali. To hear it, you have to stick your face down by the tailpipes. Otherwise you really don't hear it. I see that most of the clips out there have the cameras sitting on the ground by the tailpipes as well...
Old 11-05-2006, 12:05 PM
MiaSSmaro98's Avatar
good to hear that the tps relearn will work on a a4 well
