radiator replacement
Old 11-04-2006, 01:42 PM
drdarkman's Avatar
Angry radiator replacement
well i'm replacing the radiator on my 93 formula. anything specific that i might need to know about this? first time i've done it before. so i may need a little walkthrough. thanks in advance
Old 11-04-2006, 04:39 PM
UA-Plumber's Avatar
Buy a Haynes manual.
Old 11-04-2006, 04:44 PM
JimboManJones's Avatar
I actually just did this on a friends car, its not hard at all, we took it out and put it in through the top, if you want a write up, I'll make one for ya
Old 11-04-2006, 04:53 PM
UA-Plumber's Avatar
Just make sure you drain it well, have a tarp of cardboard down. Id get a flush when everything is done. How old is your water pump and opti? Might want to think about changing those while your in there. Take your time and dont get in a hurry. My .02 Good Luck! Post if you have any questions.
Bryan
Old 11-04-2006, 05:23 PM
Internet Mechanic
BlackScreaminMachine's Avatar
One bit of advice is patience, if you still have AC you want to make sure you dont mess that up, You can take the fans from the bottom as well as the radiator. Attatch the hoses before you put the fans on.
Quick Reply: radiator replacement
