What would you do?
What would you do?
I will be picking up a 01 Z06 this weekend and have some money set a side for some performance stuff. The car already has a small cam and lt's with your usual bolt ons. I will enjoy the car for a little while then I have 2 options...
1) Get a KB for it and run 7-8lbs for a while making 530-550hp.
2) I got a quote from a local engine builder that is known for great work (superior automotive)
383ci
Forged everything
Coated pistons
We talked about so much I am not sure if he said AFR heads or LS7?
Comp cams
90mm TB
He quoted me just under $10g's for the longblock and said it would make at least 550hp.
383ci
Forged everything
Coated pistons
Comp cams
90mm TB
11Second Club
If it were me, I'd invest in the KB, enjoy it for a while, and then consider building a forged 408 for the KB and make mad power. Keep in mind that those numbers you're quoting are just peak numbers. 530HP out of a KB is going to be significantly faster than 550HP out of a N/A motor. The KB will give you a table-top torque curve that just can't be beat.
