CNC Ported Assembled 243 Castings $995 per pair !!
Santa has come early and dropped a large shipment of 243 castings at our door. So until 12/10/2006, we are going to be offering an early Christmas special on these heads. Here are the specs:
Brand NEW 243 Castings
New OEM GM 2.00"/1.55" (non-sodium) Valves
CNC Ported 227 +/- Intake Runners
Flow 300+ @.600"
Patriot Gold Springs
Titanium Retainers
Super 7 Machined Locks
Viton Rubber Seals
Flow Sheet Specific to Each Set
Milled to Your Specs
OEM Head Bolts Included
These heads will be $995.00 per pair, assembled !!
This sale is for a limited time.
Get into the Christmas money and make sure you have a set of these under your tree !!!
Flow 300+ @.600"
Titanium Retainers
Viton Rubber Seals
Originally Posted by SLP4CamaroSS
im talkign abotu the ls6 blank heads or the LS6 Style Chamber Only Heads:
The "chamber only heads" are our LS6 style heads. If you will give us a call, we will be glad to come with a price for you. We will also sell you a set of bare as-cast 243's if you are interested.
Here is a flow from a set that were tested this morning. This flow is attained on our Superflow 1020, 3.900" bore, and 227 +/- intake runner.
I'm new to the casting numbers. Your site names the ls6 from a 035 casting which is the 243? ls1 lq 5.3 ? I have a 600 lift cam in my car and am looking for a cheap but strong set of heads and am trying to figure out all of the particulars.
