Ford SV0 42 green top injector part number?
I searched and searched and could not locate the number. I tried looking through Summit and Jegs but they list like 3 different 42s. What's the correct part number?
Also, comparing part numbers between Jegs and Summit, they don't match up.
Summit Racing:
M-9593-F302 $380
M-9593-F302F $495
Jegs:
M-9593-F302F $495
M-9593-F304 $263
M-9593-F304F $280
Summit Racing:
M-9593-F302 $380
M-9593-F302F $495
Jegs:
M-9593-F302F $495
M-9593-F304 $263
M-9593-F304F $280
http://www.fordracingparts.com/parts...Fuel%20Systems
You'll notice the F series injectors are flow matched. If you want that you might be able to pick them up cheaper from Precision Turbo.
They have flow matched 42#'s on fleabay for $280 shipped. Flow matching will give you optimal performance/tuning since each cylinder will be performing much closer than with non-matched injectors. If normally they can vary more than 7%...that means that you can be losing as much as 3.5hp (on a 400hp motor) per cylinder! You're tuning for the "average" so some cylinders could be 7% richer or leaner than the one next to it.
Will it hurt your motor? Probably not. But if you can get matched for similar prices to non-matched...isn't that a DUH?
Originally Posted by Dragaholic
How come they're so cheap on Ebay? How can you be sure they're new, flow matched, and the lb. that they're advertised as? On both Jegs and Summit, a set of flow matched 42s go for $495.
So would you say I need or should stick with the flow matched set or just the regular ones? When I had the SVO 30s, I don't believe they were flow matched and never had a problem with them.
Racetronix flow matches them to 1% according to their claims. Not sure what Ford does. They say an unmatched set can vary from 5-7%. Even if you have a set that's matched within 1%, that's a whole lot better than 5-7%. I think at that point it wouldn't really matter where the injectors are placed because there are plenty of people here running SVO injectors that aren't even matched.
"Ford Racing has flowed a large quantity of injectors, and sorted and matched injectors with similar flow rates. These injectors are then packaged in sets. The end result is fuel injector sets with very small variations in flow. Typical production injectors can vary as much as 6 to 7 percent. These kits vary less than 1 percent, but typically vary less than .5 percent. The result is improved fuel control and optimized performance, driveability and economy. These injectors are attractively priced and cannot be duplicated for the price.
NOTE: These injectors are flowed at 40-psi differential pressure, and a flow data summary is included in the package."
Do those ev1 injectors just plug right in or would new injector pigtails need to be soldered on? Also how do they fit into the manifold? I was under the impression the EV6 injectors were the same ones we use.
Sweet thanks.
Since I jacked this thread I may as well add something to the topic.
TOP~ Ford racing matched injectors are supposed to be some of the closest matched injectors you can get. I have a set of RC injectors that are 0.91%(high 442.0cc and low 438.0cc) and they say ford racing matched are less than 0.5%. I would think that's pretty good.
