Drag Racing Tech
Guys with 4000-5500 stall what is your 60ft?
Old 11-08-2006, 09:27 PM
Houston999's Avatar
Question Guys with 4000-5500 stall what is your 60ft?
please tell us your set up. N/A foot brake(no transbrake) plz. 346ci
Old 11-08-2006, 09:42 PM
gator's 99TA's Avatar
1.473 60' on the 275 radials back when had a 4L60e. stock heads with nitrous @ 3500 lbs street car
Old 11-08-2006, 10:37 PM
Retired Street Racer
Matt D's Avatar
Click the HOMEPAGE link in my sig for all of my mods on my 00 Z28. 4600 converter, cam only, off a foot brake. 1.46 60ft.
Old 11-08-2006, 10:48 PM
1QuickT-A's Avatar
I went a 1.45 on a 100 shot detuned... 4500 TCI converter with 3.50 gears and 28x10.5 M/T Drags.
Old 11-08-2006, 11:19 PM
Figz Z28's Avatar
I cut 1.59 with full int. with a 26x10.5 et street.
Old 11-09-2006, 01:11 AM
camscam02's Avatar
how are you guys leaving against these 4400-4600 converters? leaving off idle or at what rpm?!?!?
Old 11-09-2006, 07:12 AM
footbrake + skinnys + big rear gear = leaving at 2K rpms lol
Old 11-09-2006, 08:48 AM
LC
LC's Avatar
SI Car
Skinnys + 4200/2.5 + 4.56 + 28s = 1.800 60ft
Old 11-09-2006, 09:16 AM
omcar's Avatar
Default Check it out
3600 stall and 3.23 gears stock car..no headers..1.61 60'..
Old 11-09-2006, 10:49 AM
Houston999's Avatar
how no header
Old 11-09-2006, 01:27 PM
Matt D's Avatar
Foot brake launch at 4000 rpms
Old 11-09-2006, 01:34 PM
camscam02's Avatar
how should i leave with 4400 stall, 4.10's and M/t 28" drags?!!?
Old 11-09-2006, 01:41 PM
Matt D's Avatar
Different converters react differently. Try stalling it up to about 1500, then stomp on the gas or "flash" the converter on the second yellow light. Also try to footbrake it as high as you can without braking the tires loose. See which nets you the better time. I always had the best luck with foot braking as high as I could. I would invest in a proportioning valve for your brakes. It does wonders.
Old 11-09-2006, 04:07 PM
camscam02's Avatar
why a porportioning valve?
Old 11-09-2006, 07:05 PM
ALL UC2's Avatar
best i have is a 1.53 with a 4000 with th350 and 4.10s with 26/10.50 et streets
Old 11-09-2006, 10:05 PM
Matt D's Avatar
It allows you to put more braking pressure on just the fronts. This way you can foot brake higher. That's what I used.
Old 11-10-2006, 12:05 AM
Houston999's Avatar
but if you have skinnies it will not help alot!?
Old 11-10-2006, 07:32 AM
Matt D's Avatar
I never had that problem. I ran 10.85 on 17" drag radials.
But the valve does help out even with skinnies. When I did have skinnies on the car, I had a small 4000 converter, and it like to be flashed.
Old 11-10-2006, 01:11 PM
Resident Racing Jerk
vtec's Avatar
I think you mean more pressure on the REAR brakes.
Old 11-10-2006, 01:39 PM
Matt D's Avatar
Well, for launching yeah, but you can adjust it to more pressure in the front or rear. You just have to find the sweet spot ya know. Every car is different.
Quick Reply: Guys with 4000-5500 stall what is your 60ft?
