Advanced Engineering Tech For the more hardcore LS1TECH residents
Deck Height Irregularities
Old 11-13-2006, 06:31 AM
gtpvette's Avatar
Default Deck Height Irregularities
Guys,
I知 finally getting around to final assembly and I was measuring deck heights today of my rebuilt short block. What I found is the passenger side is all about .016-.017 out of the hole (block was decked) but the driver side appears somewhat off. I知 measuring .018, .019, 020 and .022 from the front to the back with an average of .020 across that side. It just seems that this deck was cut at an angle .
Should I be a bit upset with my machinist or is this reasonable??
With the variance side to side (avg .004),, should I adjust gagket thickness?
Thanks!
Old 11-13-2006, 01:35 PM
SStrokerAce's Avatar
Yeah I would wonder about that one. It's not to hard to get them within .001" on all 4 corners.
Bret
Old 11-13-2006, 01:49 PM
6 & 8 Second Club
mrdragster1970's Avatar
Decking a block is actually one of the easiest things to machine.
It should right on.
Old 11-13-2006, 07:48 PM
machinistone's Avatar
Do they not have a Block-tru fixture?
Old 11-13-2006, 08:08 PM
seadonky's Avatar
Im no machinist, but I would be showing the machine shop my pimp hand.
Either that or you are measuring it wrong, using a chickity china tool.
Old 11-13-2006, 08:11 PM
howard wolf's Avatar
I use a Block Pro CNC vertical mill to deck my LS blocks. The reference is off the crankshaft centerline. I find that almost all of the blocks are ~.004" lower in the front vs. the rear.
Old 11-13-2006, 08:52 PM
gametech's Avatar
LS1Tech 20 Year Member
That's damn interesting. Is that difference enough to cause a CR ratio difference that could account for the abundance of blown #7 pistons we always here about?
Old 11-14-2006, 12:01 AM
LS1TECH Sponsor
Steve - Race Eng's Avatar
Default decking
Howard is right about all used blocks being shorter at the front. The decks are always twisted as well. They will be about .005" lower on the exhaust side of cylinder 1 but less on the intake side. Also, most all blocks I have checked are higher for some reason on the right bank. Same front to rear deck height variance.
New blocks I check are pretty close front to rear but not left bank to right. It is not clear why the blocks tend to sag at the front. Motor mounts may have something to do with this.
In any event, if your block was decked off the mains, it should be a lot closer side to side and front to back than what you have. Use the same piston and rod to check all four corners of the block. Wrap masking tape evenly around the ring land area of the piston until it just fits in the bore. Measure at several points around the piston and average your readings.
Steve
__________________
Steve Demirjian
Race Engine Development
Oceanside, Ca.
760-630-0450
web: www.raceenginedevelopment.com/
e-mail: race-engine-development@***.net
Old 11-14-2006, 12:12 AM
SScam68's Avatar
Steve
From thermal loading?
Old 11-14-2006, 08:09 AM
Adrenaline_Z's Avatar
Excellent points. You could be measuring a difference in the rod/pin/piston
assembly, and/or the piston has rocked in the bore.
