Cam Ideas
im slowly understandin cams and stuff guys. someone please explain to me "rod bolts and fly cutting".... i understand cam specs... but what does the +4 after the LSA mean? sorry to rob the thread
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It isn't the lift that determines the "flycut". It is valve events in general. Intake/exhaust duration and lift + lobe separation. You know that is a whole different animal going solid. Valve adjustments will be critical periodically. I hope you arent planning on DD'ing this cam.
Originally Posted by SOMSS
With that cam you aren't going to make any useable torque or hp below 4K rpm, not a street friendly cam at all. Great for WOT but that's about it.
Originally Posted by The1N_only
This cam isnt much bigger than the T-rex this is a solid roller lobe with 2.5 degrees more overlap
Still, not a cam for the faint of heart. Neither is a 4600 stall. Good luck with your build.
Your cam is showing to have a 109* LSA with 4* of advance ground into it, giving you your intake centerline of 105*. You can also figure your exh centerline from this info, which is 113*. This is how the cam companies reference things to make it faster for them when they go to grind a cam.
Have fun with your combo. I hope that nothing decides to come apart on you.
