Cam Ideas
Old Nov 13, 2006 | 08:14 PM
The1N_only's Avatar
Default Cam Ideas
Ive been tossing around a few different ideas, and this is what i cam up with 243/248 .653/.648 109+4 this is on the new XFI solid roller lobe. This will be in a stock bottem end with a set of prc stage one heads... Cam experts whats your .02
Old Nov 13, 2006 | 08:18 PM
ls1muscle's Avatar
Should idle like stock.
Hello rod bolts.
Old Nov 13, 2006 | 08:20 PM
The1N_only's Avatar
yeah, rod bolts and fly cutting
Old Nov 13, 2006 | 08:21 PM
pdd's Avatar
pdd
dam you'll have to spin that biatch to 7 plus grand
Old Nov 13, 2006 | 08:22 PM
The1N_only's Avatar
i was thinking along the lines of 7200-7400
Old Nov 13, 2006 | 11:46 PM
sdavis2702's Avatar
im slowly understandin cams and stuff guys. someone please explain to me "rod bolts and fly cutting".... i understand cam specs... but what does the +4 after the LSA mean? sorry to rob the thread
Old Nov 14, 2006 | 02:18 AM
01CaMMMaro's Avatar
rod bolts are the bolts that go into the connecting rods... the connecting rods connect to the piston and and crank.
Old Nov 14, 2006 | 02:37 AM
mammad78's Avatar
stock pistons and .653 lift hmmmm
you have to do alot of fly cutting man
good cam though
Old Nov 14, 2006 | 02:46 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
It isn't the lift that determines the "flycut". It is valve events in general. Intake/exhaust duration and lift + lobe separation. You know that is a whole different animal going solid. Valve adjustments will be critical periodically. I hope you arent planning on DD'ing this cam.
Old Nov 14, 2006 | 02:50 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
That is the advance ground into the cam. Most off the shelf cams are +2 or +4.
Old Nov 14, 2006 | 06:39 AM
The1N_only's Avatar
The wont be DD, but it will see some street time. I dont mind tinkering and what not... so valve adjustments isnt a big deal
Old Nov 14, 2006 | 06:52 AM
SOMSS's Avatar
With that cam you aren't going to make any useable torque or hp below 4K rpm, not a street friendly cam at all. Great for WOT but that's about it.
Old Nov 14, 2006 | 07:10 AM
The1N_only's Avatar
Im not building this for the street, but it will see some street time. It wont be very much, but with a 4600 stall hp and tq down low shouldnt be a problem just press down with the right foot a little more
Old Nov 14, 2006 | 07:13 AM
The1N_only's Avatar
This cam isnt much bigger than the T-rex this is a solid roller lobe with 2.5 degrees more overlap
Old Nov 14, 2006 | 07:22 AM
The1N_only's Avatar
i would like to get a set of the new trick flow heads and have them milled down to 58ccs and run a .040 head gasket, but i dont know if i can make it all fit... Anyone else try something like this, or am i asking for too much lol
Old Nov 15, 2006 | 12:19 PM
The1N_only's Avatar
what would you say the highest DCR you can run with 93 octane?
Old Nov 15, 2006 | 02:23 PM
hammertime's Avatar
By the time your lifter clearance is taken up, you'll probably end up smaller effective duration than a TRex.
Still, not a cam for the faint of heart. Neither is a 4600 stall. Good luck with your build.
Old Nov 16, 2006 | 03:40 PM
1997bird's Avatar
Your cam is showing to have a 109* LSA with 4* of advance ground into it, giving you your intake centerline of 105*. You can also figure your exh centerline from this info, which is 113*. This is how the cam companies reference things to make it faster for them when they go to grind a cam.
Have fun with your combo. I hope that nothing decides to come apart on you.
Old Nov 17, 2006 | 02:22 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
27° of overlap will be a prostock idle.
Old Nov 17, 2006 | 06:24 PM
LSX-Racer's Avatar
Banned - Ed Curtis aka EDC
Pro Stockers idle pretty nice compared to some of the LSX "cam only" cars I've seen.
