What would cause my car to rev pretty high?
Just as posted what would cause my car to rev like this. I notice this today after I turned the car on and it seemed to be searching for an idle. When I pushed on the gas pedal it reved to about 4000 rpms and stayed there for about 30 secs before finding an idle again. The only thing I did to the car is tighten the belt on the d-1 because I suspected that it was slipping (only getting 5 psi). Well after a few WOT runs I parked the car and today I turned the car on and it revved like I mentioned. This has happened a few times before, but this was the first time in about 2 months since the last time it did it.. The only thing I can think of is that I have an intake leak since I installed it myself and it is probably lifting since I retighten the belt and now seeing full boost. What do you guys think should I go an retorque the intake or does anyone have any ideas as to what it might be???? HELP PLEASE!!!
I did do the manual check yesterday and it just revved just as when I pressed on the gas pedal.. The only weird thing about it is that it only does it on diffrent occassions.. I suspect that since I retighten the belt on the d-1 and now seeing full boost I'm probably lifting the intake some what and causing a vacuum leak. Does everyone agree on this?? Thanks Andy
Sounds like some type of intake leak to me as well . Tough to say where though . Never had a throttle body stick that bad though I have ran into a few intake manifolds that had bad intake seals that will keep the idle high but they will rev high as soon as you crank it up just sucking in air .
