View Poll Results: Which mod
MSD ignition, Coil
0
0%
LT's, ORY, Borla muffler
44
95.65%
K&N CAI, MAS
1
2.17%
Crane Cam
1
2.17%
Voters: 46. You may not vote on this poll
Best Perf. Outcome 94' LT1 M6
My GF is getting me a gift card for my b-day. Either to Jegs or Summit, I dont know which one yet. Which mod will give me the best results.
K&N CAI with a HP MAS
LT's, ORY, Borla XR-1 Muffler
MSD ignition, Coil
Crane Cam
Does JEgs or Summit have more/better/cheaper LT1 Parts?
MSD ignition, Coil
Crane Cam
LT's and ORY + catback will definately be best for you as far as gains. But that is way more expensive than a CAI. If you want something cheap a K&N will definately be good to have but exhaust is they way to go if you have more to spend.
Originally Posted by 94lt1m6
lol open up your mouth and butthole? I have nevr heard it called that before but ok. if i get the headers how hard will it be to delete the emmisions ****?
the EGR is pretty simple too. you'll need to remove the EGR valve on the back of the intake and the pipe next to it. then you'll have to either buy EGR block off plates or make your own (not hard to do.)
you might want to look into getting a tune for the full exhaust and EGR/AIR delete. if you're gonna get gears in the near future wait until they are installed so you can correct your speedo at the same time.
as for a CAI, don't waste your money on a new one. go look on ebay or in the for sale forums here for a used one. moroso and K&N are supposed to be good. I had an SLP cai and I didnt really care for it.
one more suggestion: instead of a borla XR-1 muffler, spend the money on an electric cut out. that way it will be loud and free flowing when you want it and quiet when you want it. just keep the stock catback on there.
if you want a cold air intake for a steal, send me a pm. i bought a brand new k&n fipk and had it on my car for about a week then i put a new oversized aluminum radiator on the car and it took up much of the space the intake uses. so i had to come up with something else.
so i have a basically brand new k&n fipk just chillin, all you need is a filter for it, i used the filter on my custom intake. filters about 30 bucks. shoot me a pm if you are interested. i will cut you a deal.
Try one of the sponcers on here. I ordered some stuff from www.Ws6store.com I really liked the service.
Exhaust. You will get some gains but, most of all, you will get to hear the results of your efforts every time you stomp on it. A cam would be good but, need to have all the other stuff in order for that to be worthwhile.
I would start with the suspension first. You will gain more from working on it than from small bolt on's. I would get the Energy Suspension torque arm bushing, Lakewood rear control arms and adjustable pan hard rod bar, and the KYB 5 way adjustable struts. For the rear springs you can go to your local parts store and get a set for a 79' Chevy Monza with the V-8 motor. These are about $42 here in NM. This set of rear springs are the right heigth and diameter but a much softer spring rate. My freind had a set of Eibach drag launch springs and got rid of them for this set because they helped him 60 ft better. With the rest of the sugested suspension parts your car with actually handle better than what your car would stock for a bonus.
I would pass on the aftermarket mass air flow sensor. I have one, put it on for like 5 mins and took it off. Some people say u have to tune for it but I dont know how.
Originally Posted by Ryan34
Just out of curiosity, how does a softer spring rate help your launch? Also how do those springs affect handling?
a cam will not do near as much do a stock "breathing" car. Get a CAI, or build one for that matter....and get a free flowing exhaust.
from your choices i selected LTs, ORY, Borla....altho I would recommend a true dual.....Long Tubes and True Duals are incredible!! but I am biased!
