Is my fuel pump dead?
Took my car down this weekend to start installing gauges (boost and fuel pressure), which I didn't finish for lack of certain parts. So I put everything back together, plugged the ECM and battery back in and go to start the car, just sits and cranks and will not turn over. Do a little investigating and I'm not getting any fuel to the rails (nothing came out of the schrader valve). So I turn the key on to check to see if i can hear the pump priming...nothing. I'm 90% sure it's dead. No noise, fuse is good, relay is good. Anything else to try?
I was routing wires throught the grommet behind the PCM. I actually got it running last night, I just unplugged the PCM again and plugged it back in a few minutes later.
