Fuel Rail Question-Single Line, Dual Line, etc.
On my conversion, it would be simpler to use a single line set-up to the Corvette fuel filter/regulator mounted on the frame, and then two lines out to the sending unit/fuel pump in the gas tank. I was planning on using the AC-Delco 241 fuel pump attached to a factory style 87+ FI Blazer sending unit on my 1981 Blazer K5.
Is there any difference between the single line Camaro and Corvette fuel rails?
Any help would be appreciated.
Nate
