question about the trap door method
Be careful not to go deep, and not only will you cut into the tank you will cut the 3 pipes that come out of the top of the tank which are even closer to the metal you are cutting.
Get a dremel, be patient, take time doing it. If you rush it may take you 10mins less, but dont forget that hole will be there for the life of the car.
Differnent years require a hole in a different place, eg. I beleiw '99 to a 2000 TA the trap doorneed to be in a different place, only about 8 inches different, but best to check before you cut.
I used a sheel of aluminum with some sticky back foam and screws to seal the hole up afterwards.
The pump is held in with a large locking ring. You need to tun this anti-click widwI tihnk, you will see buy how its latched in. The first time done this I made sure the top of the tank was dry (no fuel) and hit this ring with a screw driver and hammer, be careful not to puncture the tank, but eventually I got the ring to turn, and lifted the pump out.
