F.I. guys with 1000-1200hp fuel set up???
Hey guys. I have a 98 camaro and I need to put together a fuel system that will support 1000-1200 hp. Is there anyone out there with this amount of power that can help me out? thanks.
Get your 98 tank sumped. Run a -10 AN line with a y to any fuel rails you wish to buy and run a return back to the tank with a bulkhead fitting. Get a magnafuel 4303 or a areomotive pump to handle the fuel demand. Pick you own fuel regulator and get a electric fuel pressure gauge.
Fuel System
http://www.exoticperformanceplus.com...Car.php?car=42
Check out the fuel system that we installed on this '98. I have the Aeromotive part numbers that were used listed. Bob
Of course do not forget about the larger injectors, im going with 96lb/hr. I went with the MagnaFuel 4303, rated up to about 1400rwhp. You will need either an aftermarket Computer system, i went with a Fast XFI or the Converter Box that will allow you too run larger fuel injectors which is a must at that level of horsepower. To make it easy check out Nasty Performance Site http://www.nastyperformance.com/FuelSystems.html I went with the Stage 2 Street/Race Kit that came with everything I needed.
Originally Posted by MIGHTYMOUSE
i run a stock 98 tank, twin walbro 255's w/ dedicated relays on the stock sending unit, -8 line out to aftermarket rails and regulator. and the retun line is the stock pressure line, 96# injectors
I just got all my stuff other than the fittings...
Weldon 2025 pump
-12 feed to pump
-10 feed to Y block
-8 feed to rails from Y block
-8 return line
Nasty Nate Sumped tank for GTO
Pre and Post Filters
Aeromotive Pro Series Fuel Pressure Regulator
Aeromotive Fuel Rails
160# Injectors
Big Stuff 3
Now I need to decide how I want to plumb the entire system and order my fittings!
Weldon 2025 pump
-12 feed to pump
-10 feed to Y block
-8 return line
160# Injectors
Big Stuff 3
Originally Posted by gator's 99TA
why isnt stenod doing this for ya mick?
I have complete feul systems for your needs. We can custom tailor it for your needs give me a call.
Nate
Nate
Nate
Nate
LOL But if you want to go heavy hitter style there always Nate! Thats what I am using
Well I would say 1000-1200hp is pretty heavy???
