my car drank 2 qts of oil in 2k miles!
Originally Posted by ls2 bait
any ideas? its not smoking and the motor is bone dry underneath. not a drip anywhere. under wot all i get is a little puff like its blowing out the intial hit of fuel and then nada. someone stealing my oil or what?
You need a valve job.
If the smoke continued during heavy acceleration than its your rings, like mine.
And don't feel bad, I use 2 qrts every 200 miles....yes.....200.
i find it hard to belive i need a valve job on a car with 20k on it but i guess its possible. time for some heads.
Before you do anything, do some analysis - leak down test, look at your plugs, check for oil in the intake by pulling the TB and look in the intake, etc.
Originally Posted by DaddySS
Actually I don't think that's correct. The symptom for using oil through the seals is smoke on deceleration and start up after sitting. Smoke on acceleration is rings. There is a TSB on the LS1 using oil on high RPM light load usage. Do you keep the revs up there a lot?
there is oil in the intake but that could be from the pcv. the car rarely goes over 3k unless im running someone which has been rare lately. im going to pull the plugs this weekend and see if any are wet.
DaddySS,
Smoke during the entire time accelerating is bad rings. Bad rings will smoke all the time under any kind of acceleration. But if you just a get a cloud when you nail the gas, then it clears up "as you continue" to accelerate, its the vlave seals sucking it in when the pressure takes a sharp drop when you nail it and sucks in a big gulp of oil through the seals.
I had his exact symptoms, had the heads rebuilt and it was 100% gone.
Originally Posted by Quickin
Oil in the intake is also a sign of valve seals gone bad. I say remove the intake and see if there's a shitload of oil build-up going towards the cylinders, if yes...valve seals for sure.
DaddySS,
DaddySS,
Dam Tommy, I thought I was having bad luck. I have the same thing going on as well. I put a catch can in, and it has been halping, but I still loose a bit and the catch can is dry. I am going to be sending the heads out to TEA and hope that fixes it. While it is torn apart I will be lookign at the whole motor and might be replacing the rings.
UPDATE: i pulled the plugs today and every one of them was bone dry. a little on the white side so i think its running a tad lean but i dont know what to do now. i put a new pcv in and ill see if it stops. if not ill try a catch can. i dont know where the hell else it could be going.
