What size/thread is a O2 sensor hole?
Old 11-18-2006, 08:38 PM
SPANKY LS1's Avatar
Default What size/thread is a O2 sensor hole?
I need to plug some O2 sensor holes on my x-pipe (for some reason, it has holes where the back O2 sensors would go, but its an off road pipe). Anyone know what size/thread fitting I need to "plug" these openings?
Thanks, Shawn
Old 11-18-2006, 09:28 PM
N4cer's Avatar
Oh man I forget the thread pitch, but it's 18mm diameter. It's the exact same as a spark plug. They have plug bolts that fit O2 bungs. They hang on a rack in Advance Auto stores, back by the oil and stuff.
Old 11-20-2006, 03:24 PM
SPANKY LS1's Avatar
Anyone know?
Old 11-20-2006, 03:35 PM
TchargedLS1TA's Avatar
18mm x 1.5mm
Old 11-20-2006, 03:36 PM
Moderator
jimmyblue's Avatar
If it has threaded bungs then get a couple of
Toyota oil pan drain plugs, 18mm size, off the
rack in the AutoZone/whatever oil change section.
Old 11-20-2006, 06:27 PM
SPANKY LS1's Avatar
Thank you.
Old 11-20-2006, 10:10 PM
Sigforty's Avatar
Good info there!
Quick Reply: What size/thread is a O2 sensor hole?
