Need help predicting this cam
What should I expect from this setup with the engine specs below? Power estimates? Power band? Does anybody have anything close to this setup? How does the overlap in the cam look? Would your opinions change if up to a 200 nitrous hit were involved?
Comp XER @adv(287/289) @.050"(238/240) .604/.609 112+2
Seat Timing ......OPEN ............. CLOSE
INTAKE:......... 33.5 BTDC ........ 73.5 ABDC
EXHAUST:.......78.5 BBDC ......... 30.5 ATDC
OVERLAP 64 degrees
Engne Specs. with M6 transmission
Block: 4"bore, 4"stroke -->402ci -->Dynamic compression ratio 8.89:1
Heads: approx 345cfm intake and 240cfm exhaust
Intake: FAST 90/90
Exhuast: 1 3/4" LTs
OVERLAP 64 degrees
Intake: FAST 90/90
Exhuast: 1 3/4" LTs
