Head Gasket?
Old 11-20-2006, 11:49 AM
speedracer5532's Avatar
Default Head Gasket?
Which head gasket is everyone running for a forced induction application? I am thinking about running the SCE Titan ICS gasket, but when I talked with them they say that you need to retorque their head gasket. I have had good luck with Cometics and the Fel-Pro 1041 head gasket in a normally aspirated application.
Old 11-20-2006, 11:52 AM
6 Second Club Moderator
LASTLS1's Avatar
gm mls.
Old 11-20-2006, 12:02 PM
JMBLOWNWS6's Avatar
Using GM mls Copper coated. ARP 12 point studs to 75#'s
Old 11-20-2006, 05:53 PM
JPH
JPH's Avatar
cometics here.
Old 11-20-2006, 06:31 PM
Ed Blown Vert's Avatar
Originally Posted by LASTLS1
gm mls.
Yep, GM MLS with studs
Old 11-20-2006, 07:12 PM
I forgot to mention that I have AFR 225 heads which have a 4.10 bore chamber so I would need at least a 4.130 bore gasket. I do have the ARP studs.
I would like to hear from the people that have run the SCE Titan ICS gasket.
Old 11-20-2006, 08:54 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,103 Likes on 723 Posts
Gm Mls
Old 11-20-2006, 10:31 PM
LASTLS1's Avatar
Those were the very first set I blew on the dyno.
Old 11-21-2006, 01:31 AM
SSmokin 01's Avatar
Gm Mls.
Old 11-21-2006, 07:04 PM
nitrorocket's Avatar
Can someone please sticky MLS in big letters in the top of this forum.
PLEASE!
Old 11-21-2006, 07:58 PM
SSblack98's Avatar
Can someone please explain to me what GM MLS gaskets have a 4.125 bore or larger? Maybe the LS7 gaskets?
I could be wrong but I don't think the bore on the LS2 gaskets will work on a AFR 225 without shrowding the valves.
Quick Reply: Head Gasket?
