Milling Heads
Milling Heads
How much would I have to mill my heads to get a a minimum 14:1 compression ration.
64cc chamber
4.060 bore
3.750 stroke
7cc dome on pistons
.040 cometic gasket
64cc chamber
4.060 bore
3.750 stroke
7cc dome on pistons
.040 cometic gasket
THRU MY CALCULATIONS, I FIGURED YOU HAD A GASKET BORE OF 4.100", and a -.010 deck height, and getting the chamber down to 61cc would get you actally 14:1. which would mean .006 usually per cc, so 64-61=3 and 3ccX.006=.018. .018-.020 should get you there. tell me your gasket bore size and deck height(how farpiston protrudes out of deck) and i will give you a more exact figure.
