STS Turbo Air Filter Cover - Guess what we found?
The customer (Scott) of the Camaro SS with the STS Turbo that we built brought his car back in to us to have us redo the fuel system, and run the return oil line to a better location than the valve cover. Scott called the other day and mentioned he heard the cover that STS has been sending out with the kits to keep water out of the air filter is proving to be pretty restrictive. We just happened to have Scott's Camaro on the dyno today, and we found an extra 35 rwhp with the cover removed from the filter!!! We tried this several times with the same results, and that is with a clean filter, etc. Bob
Originally Posted by Slowhawk
Yes,the filter sock is a restriction,major restriction on high boost.We found that out when STS first released the kit's.
and yet if you call up STS and speak to one of their "not so bright" sales guys.. they will tell you "oh.. you only loose about 1-2hp".. pfff
