gas smell
gas smell
i get a gas smell from the rear of the car right after i park from driving, or come up to a light and sit there for a little while. i think its the charcoal canister, and/or the filler hose. gas cap is brand new and its 3-4 clicks tight on the car.
has anyone else had this problem?
Mine did the same thing but only after I filled it up, drove me crazy and it started doing this after I had a new fuel pump put in. Anyway I finally found it and it was a cracked filler neck right where it meets the tank. Hey jd783, how did you do yours through the top?? If it ever goes out again I will be doing it that way also. Was a bitch the other way!
