Witch one flows better?
Tech Resident
you'll see better performance through the true dual system with 3" single chamber flows. it's not all about flow. flow is VASTLY overrated. a y-pipe with an open cutout and true duals w/single chambers will likely BOTH flow very similarly and support your engine WELL PAST the horsepower rating your car likely has. what you need to worry about is scavenging as this is where the real power comes in.
true duals are simply better for power. they take each manifold and scavenge them individually. since you don't have two different sides of the engine's air colliding at a single point into the I-pipe of a y-pipe, the exhaust gases simply leave more efficiently. not to mention, the X-pipes and H-pipes simply scavenge better due to the way it balances the pulses of gas.
in short, true duals just produce more power. flow doesn't matter as a good catback and true duals will both support the horsepower level you're making. it's about scavenging and exhaust velocity at this point, and true duals are the winner hands down.
Also LG who make arguably the best headers for Corvettes actually turn their X pipe into a Y pipe for their race cars.
Tech Resident
Originally Posted by 300bhp/ton
Actually that would be the header not the mid pipe.
When I spoke to a Magnaflow engineer a while back he came to the conclusion that a Y pipe scavengies in the same manner as an X pipe.
-flow
-scavenging
-exhaust velocity
you need all three. a y-pipe may flow nearly as well as an X-pipe/H-pipe and it may scavenge decently, but when the gases collide, they slow. true duals show more power than y-pipe setups because the gases flow independently. they don't interfere with each other except when they balance out towards the end. true duals are just better than a y-pipe. period.
i can't stress this enough: BOTH ARE NOT EQUAL. a y-pipe setup will NEVER have the potential of a true dual setup, and even on a stock motor with stock power, the perfect true dual system will outperform the perfect y-pipe setup. guaranteed.
Originally Posted by chrs1313
both are around equal, if you want to lose some weight go with the duals...or save the money and just get a cutout
the reason I ask is becouse I have the TD set up I described its sounds awsome..but its so damn load in the car and rattles my console..and I was thinking if power is equal I might change..
My car sounds like stock with the cutout closed and a beast when it is open, so you have the best of both worlds...dont listen to taco yeah duals may be a little better but i doubt it is that much, i mean if you think about it the gases collide too in the X pipe just like in the Y...the reason for doing dual should be sound, or lose weight, cutout is just so much more practical...i mean look at my times think it doesn't work...
Tech Resident
don't listen to me? don't listen to physics. duals produce more hp/tq than a y-pipe setup. they are better on any and every setup assuming they're a quality setup. case. closed.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Jesus Tony!
